2. How do you get the unevenness (height difference) between the front and rear halves filled? It seems you will have to fill OVER the gap, which in effect will fuse them to some degree. I have the same problem picturing how to do this on the cabin doors. I know how to get the gap looking good. Not sure how the get them to same profile without filling across the gap.
Thanks.
Johan
With regards to the doors, I did the following;
1. I did not follow Van's instruction re fitting a 45* edge on the doors to the rounded corner of the cabin top. The edge on my green top was so inconsistent that it was impossible to fit the door edge to it. The steps below left me with a squared off door edge and a squared off cabin opening edge. Looks good and has held up well over almost 4 years.
2. Trim the doors to fit the cabin opening; install the door hinges, door pins & guides, as well as any secondary latches, and adjust them to their final positions.
3. Trim & sand the door edge so it is 90* to the outer face of the door. Apply 3 layers of duct tape to the door edge, around the entire door. It will be perpendicular to the outer door face. With a razor blade, trim the duct tape, using the outer face of the door as your guide. The edge of the duct tape will be flush with the door face. Some of the duct tape will extend towards the inside of the door. The thickness of the duct tape will determine the final gap between door and cabin top. Take a little time to apply it so you have the same thickness all the way around the door; no wrinkles, no gaps. Three layers of tape left me with a final gap of about 1/16th inch, once primed and painted. Add more layers of tape if you want a bigger gap.
4. Close one door, making sure the duct tape doesn't pull away from the door edge. Fully latch the door. With a squeegee or similar tool apply micro to fill any low spots. In my case, the door was higher than the cabin edge all the way around. Filling the low spots on the cabin side also turned the original inconsistent round edge into a nice smooth squared edge.
5. After the micro has thoroughly cured, open the door from the inside. It will probably take some gentle pushing. You may have some minor breakout of the edges on either side of the tape. Pull the tape off and admire your fitted doors.
Jim Berry
Rv-10
