flyenforfun
Question on these filler plates behind the prop. My spinner is all cut, drilled, and screwed on. Filler plates are made, drilled and cleco'd. Now the easy part has become the hard part. I cannot come up with anything to use to rivet these plates on. My rivet squeezer wont fit, the handle hits the prop and puts the squeezer on an angle. I cant find a rivet set that will fit in there for a rivet gun, everything i try makes the gun hit the prop. Anyone else have any suggestions?
