I bought a new NUMATX squeezer for my RV-10 build. I set everything up and began practicing. It squeezes 3/32 rivets great at about 60PSI on the compressor, but when I try to squeeze 1/8th rivets I can crank the compressor as high as it will go at 120PSI and they are still slightly under squeezed. I have checked all the fittings for leaks, double checked that it was full of hydraulic fluid and bled to eliminate air from the line. Everything checks out fine, the only thing I could find wrong is I hear a faint air hissing noise coming from inside the foot pedal (not the fittings).
I’ve been trying to contact the company but they haven’t been returning my calls or email. Anybody have any insight?
Bryan
Bryan
