Maybe. I believe the plug is used to cover a clearance hole drilled through the firewall (per plans) opposite the bolt that attachs the nose gear leg to the mount. I avoided drilling that 3/4" hole by beveling the threads and clocking the bolt so that it just clears the firewall without actually touching it.
