Jonnyb
Hoping some one can help or offer reassurance.
I’m just starting out building an RV-8, and am having some issues surrounding edge distance on the HS-00003 Spar Doubler.
So standard edge distance is 2x the diameter of the rivet.
I have measured out the attach holes for the HS-702, HS-814-1 HS-810-1, HS-00003, and the HS-00005 as per Detail DD on drawing 3. However this has bought me up short on edge distance. On a previous matter with edge distance in this area Vans pointed me towards the edge distance called out in the SB (SB14-01-31) specifically page 21, and it states “The minimum allowable spar doubler edge distance is shown in Figure 14” Figure 14 shows the distance as 5/32”
The problem I have is that figure 14 is talking about the outboard most hole of the doubler, and my issue is the top attach hole for all the parts stated above.
Now I have more than the 5/32” stated in the SB but not the 1/4” standard. I would email Vans but they are all at EAA until 7/31, so I thought I would throw it out to you guys to see what you think?
What I should say is that my spar doubler, with all the holes drilled, looks exactly like the spar doubler on page 21 of the SB.
