alpinelakespilot2000
Help with how to wire jumpers on Icom radio harness
Can anyone describe to me what the jumper wiring will LOOK like for the molex power cable wiring shown in the diagram for the Icom A210 below. Since pins 11, M, P, and 13 must be jumped together, how do I do that gracefully? I can only fit one wire into each Molex pin, so this leads me to think that I'll have to use some butt splices or some other method to join the numerous wires that are coming out of those 4 holes. Suggestions?
Likewise, for the ground connections out of pins F, 6, 15, and S: what's the most graceful way to get those connected to each other and the ground--Four individual strands to ground or will I somehow connect them to teach other before running just one or two wires to the ground?
If anyone can describe this, I would be greatly indebted!!! (Just using that simple D-Sub version is looking awful good right now. Unfortunately not all the A210 features work if you use it instead of the Molex.)
![2ztm3pg.jpg](/proxy.php?image=http%3A%2F%2Fi39.tinypic.com%2F2ztm3pg.jpg&hash=e93ddce9cd91b739b8a4098d5ce5f58d)
