Nihon_Ni
I'm having trouble with the lap joints between the F-820 and F-823 fuselage skins on both sides of my RV-8. When I first tried to cleco the forward skin in place, I started at the firewall, clecoed the landing gear boxes (the holes there lined up well), but when I got the the lap joint, the holes were significantly off. The delta is about 3/32" on the right side, and 1/16" on the left. (Pics 1 & 2)
I removed the clecos and started again, this time from the bottom edge of the firewall and lap joint and clecoed up both ends. I then clecoed the landing gear boxes to the skin, which wasn't too difficult, but some of the holes took a bit of pressure to get them into position (mostly around the gear weldments). When I stood back and looked at it, I found waves across the top of the skins when viewed from the front. (Pic 3) When I looked at the side (Pic 4) I thought these waves might be caused by the bulkheads trying to curve the top of the skin, so I removed the top 8" or so of bulkhead clecos and the result looked better (Pic 5), but not perfect. When I took the skins off, there's still a lot of sheer pressure in the lap joint, and it sprung back to the position in Pics 1 & 2 when I removed the last clecos. It seems like it generates more sheer force than should be necessary or acceptable, but when I cleco the ends first and the gear towers last, it takes less effort to install the clecos than the fuel tank skin/ribs did.
As far as I can tell, everything is in alignment with the gear towers, lower longerons and cabin floor. I haven't riveted the bottom skin under the back seat yet so that might be a factor (I was waiting to prime it), but I will get that done this weekend.
Any ideas on how to proceed?
Rob
![gallery_11575_1360_29806.jpg](/proxy.php?image=http%3A%2F%2Fwww.cigarpass.com%2Fforums%2Fuploads%2Fgallery%2Falbum_1360%2Fgallery_11575_1360_29806.jpg&hash=0db6d7d44c65dd59df66ba1533aa872c)
![gallery_11575_1360_9296.jpg](/proxy.php?image=http%3A%2F%2Fwww.cigarpass.com%2Fforums%2Fuploads%2Fgallery%2Falbum_1360%2Fgallery_11575_1360_9296.jpg&hash=4cb0fce68df96e4b92903d8d2a092d7a)
![gallery_11575_1360_27760.jpg](/proxy.php?image=http%3A%2F%2Fwww.cigarpass.com%2Fforums%2Fuploads%2Fgallery%2Falbum_1360%2Fgallery_11575_1360_27760.jpg&hash=674001e665fc7cb3ba2021b05a2bdabc)
![gallery_11575_1360_19344.jpg](/proxy.php?image=http%3A%2F%2Fwww.cigarpass.com%2Fforums%2Fuploads%2Fgallery%2Falbum_1360%2Fgallery_11575_1360_19344.jpg&hash=445917d60b6e3f90d3ac380db91266c8)
![gallery_11575_1360_8667.jpg](/proxy.php?image=http%3A%2F%2Fwww.cigarpass.com%2Fforums%2Fuploads%2Fgallery%2Falbum_1360%2Fgallery_11575_1360_8667.jpg&hash=26c28bb7ebc38f6813a9e31219b52968)
Rob
