macrafic
I realized, when I tried to fit the F-721B aft canopy deck to the longeron that I had not cut enough off. Now, I've lost my reference for the measurements (the measurements on the plans all stem from the aft end of the canopy deck, which I long ago cut). Could I get some measurements/verification from you guys?
For those of you who have NOT yet cut the canopy decks, what is your measurement from front to aft on the inside flange (includiing the tab at the front)?
For those of you who HAVE cut, how much slot do you have remaining (remember, this is a tip-up, which is different from the slider)?
Also, for those of you who HAVE cut, can you verify where my understanding has gone awry (tip-up)?
- It looks like the aft 1 15/16" is cut completely off (after match drilling the longerons)
- For the tip-up, it looks like another 13/16" is cut off of the rear, but only on the inside flange, from the "slot" downward
- This leaves a slot of length x"
After all the building I've done, I have no idea why this is giving me so much trouble. I would appreciate your help!
