I just did this
I just finished my rear skirt. I made it of fiberglass, but patterned the width from the aluminum included in the kit. I cut one of the two outlined halves to form a "template", which I used to mark on the rear of the canopy and the fuse with tape.
I positioned the template so that I would have enough overlap aft to adequately cover the gaps around the slider track. This gave me about a two inch overlap on the rear of the canopy, but then, I probably trimmed the canopy a little closer to the rear of the canopy frame than some. If memory serves (I'm not at the hangar currently) the width of the skirt at the apex is about 5.5 inches, widening to about 6.5 at the side skirt intersection.
