My Mode C has been Intermittent reporting. that's what started it all.
My ADSB has stop reporting when I pull the report, always has been great, all zeros. Now won?t even generate one.
Does anyone have the same setup or close to what i have that you could help me confirm my communications settings. The wire connections are correct ( it was drawn up by steinAir) it has worked for 2 years flawless, now it?s acting up.
Here is how my wiring connections go.
Dynon D10A is my Encoder - sends out to my GTX327 (232 in2, Pin#2) and to IFD440 (same as garmin 430W, 232 in3, pin42)
-Echo UAT pin6 is connected to the IFD (232 out2, pin58)
-Echo UAT Pin4 is connected to the GTX327 (232 out1, pin20)
Now the thing I need to confirm are the settings for each unit.
GTX i have
?RS232 input
Channel 1 - OFF
Channel 2 - Icarus ALT (this is connected to my D10A/encoder)
?-Output
Icarus Alt- (this is connected to the Echo UAT )
ECho UAT I have
*setup source ? App(wifi,stored)
*Control source ? Transponder monitor
*GPS source ??External gps (com2)
*traffic/uplink out ? MFD(com2)
*com1 rate ?? 38400
*com1 data ?? 81O
*com1 PHY: ?? RS-485 terminated
*com1 Protocol: ?TMAP
*Com2 Rate ?115200
*com2 input protocol ?? NMEA
I will check what i have On my IFD440 for the settings.
All this started with a intermittent MODE C reporting. I know the ALT comes from the encoder not from the ADSB, I have replaced the GTX327 , copied the same settings from the original,. But somehow when I went to check my ADSB report, I got a "can?t be generated reply", I tried that on 2 flights. same results. ( I know about ZULU time in relation to the date)
Thanks for any clues.
Is there a way to check if the Dynon D10A encoder is the problem? or does it need to be sent in?
GTX i have
?RS232 input
Channel 1 - OFF
?-Output
ECho UAT I have
*com1 rate ?? 38400
*com1 data ?? 81O
*Com2 Rate ?115200
