Gary's RV7A
Active Member
Help... Taper pin installation - found solution...
See my last post for my solution.
Ok, I've read all the story on how hard it is to taper the hole in the nose gear strut. I'm in the middle of this and I'm so close to having a tapered hole. I'm about 3/8 of an inch short. I'm so close but I can't make any progress. The tapered reamer has a few chips in it from use. I'm assuming I need to buy a new tapered reamer... If so, what is the best reamer I can use for this project? I'm currently using a #3 brown and sharpe taper reamer. Up to this point I've been turning the reamer at 100 rpms. Is there any alternative methods to reaching the end? Thanks!
