alpinelakespilot2000
Just confirming: where is the down (forward) elevator stop on the RV-9/9A? I understand it to be flush with the fwd edge of the opening in the aft deck (and immediately under the flange cutout on the HS spar).
The problem is that my elevator horn weldments are still about a 1/4" from that location when the fwd moving control column hits the top of the seat rib cutouts. I know that opening the seat ribs more is a common issue, but I have no idea how much I'll need to open them up in order to get that last 1/4" of travel on the horns. Before I start hacking away at the seat ribs, I just figured I should confirm that the down stop is where I think it is. (FWIW, pushrods are to plans length with the center fuselage bellcrank in the vertical position at elevators neutral.)
Am I right in the location of the stop and that opening up the seat ribs more is the only solution?
Thanks.
Thanks.
