Actually I hope the situation isn't that dire, but I'm looking for some advice about how to proceed after a screw up. While riveting the inboard nose rib-spar-spacer-rib assembly, I royally screwed up a rivet and had to drill out. But thanks to the awkward angle, I ended up drilling it out at an angle, which I didn't notice until I re-riveted, and AGAIN it came out all funky. So now I have a terrible rivet off to one side of an enlarged hole. Needless to say, I've stepped away and practiced my rivet removal technique.
My thinking had been to either
-drill out again, put a reinforcement plate on the elongated side, and re-rivet
-Enlarge the hole to round, and bolt it (but I'm not sure on edge distance, although I don't see much reason to suspect shear forces at this spot), OR,
-Drill and new hole between the middle and bad rivet, and re-rivet there.
I have consulted Van's on this, but no response yet, so thought I'd seek some expert advice here as well. On a better note, aside from this issue and a couple holes waiting for 'oops' rivets to arrive, the HS is done!
![2julw5.jpg](/proxy.php?image=http%3A%2F%2Fi50.tinypic.com%2F2julw5.jpg&hash=9da7a9f62a3f4acf106324fb6f728e0e)
