Brantel
I am going to be mocking up my panel a few times, using the different platforms that I am concidering.
My mission will be an IFR ship capable of filing /G. Good autopilot integration or more capable AP to give equal features, weather and traffic is important as well as not being stuck without a backup in the soup.
Here is my first pass at a GRT based system.
As you can see the equipment list is:
Dual GRT, with weather option & ARINC interface, undecided Sport or Horizon
GRT EIS
TT DFII VSGV
ASI
TT ADI
ALT
CDI/GS
PS AP
430W
SL30
G327
GX96
AFS AOA PRO on windscreen (not show)
ZAON PCAS connected to GRT (not shown)
There will be a strip added at the bottom for switches and other items
Since this AP and the GRT go together like peas and carrots, I will have only a switch to give the AP the choice between GRT or GPS as a source.
I have a few things unsettled if I go this route.
First is how to handle the CDI/GS indicator and it's integration with this system. Its function would be to be a backup to the GRT's HSI and I would have it connected to the SL30. How can this be done in regards to the OBS setting?
Second, Sport or Horizon? Seems the Sport now does everything the Horizon does except it has fewer serial ports and no analog ports. This limits the amount of renduncancy one can have because to have total independance between units, all critical serial data must be connected to both screens. To do what I want on the Sport, some things would be lost if one or the other screen died. How important should this be concidering the equipment and other options shown here?
Third is the weather feature on the GRT, I understand it is slower and has less features than the X86. People who have used both, can you comment on which is better and why?
Fourth is a traffic solution and at this point I only see two things in my price range and that is the Zaon or the mode S transponder. I like that the Zaon works anywhere but when the mode S works, it is more accurate. So what is everyone's thoughts on what to go with? The other question is does the Zaon work with both the Sport and the Horizon?
Fifth is how to handle backup power. I really don't want two main batteries. I will have a handheld Nav/com that can be connected to the external antenna. The ADI, X96 and GRT's will have a backup battery.
Sixth is 3.125 backup instruments or 2.25? If I go with the smaller ones, the CDI/GS and the AP would just swap places and this will give more room at the bottom for other things.
Do I even need the second Nav/Com and indicator?
![2002974587514092807_rs.jpg](/proxy.php?image=http%3A%2F%2Faycu12.webshots.com%2Fimage%2F47931%2F2002974587514092807_rs.jpg&hash=19d5e8e809e3ebb5557382d80426765b)
GRT EIS
TT DFII VSGV
ASI
TT ADI
ALT
CDI/GS
PS AP
430W
SL30
G327
GX96
