RV-4 with old style long cowl, O-320 with Carburetor.
I have been adding aluminum tape to the #1 & #3 cylinder top fins as well as an air dam in front of #1 in an attempt to increase the CHT's to match those of #2 & #4. Typically #3 is the coldest cylinder averaging 30-40 degrees F lower and is also the richest cylinder. #4 is the leanest cylinder.
#2 & #4 are withing 1-2 degrees of each other (Avg. 340) no tape, no air dam.
I have done all the sealing with silicone I can & baffles/seals are in good condition.
Pictured in this post is the current taping job which has increased #1 & #3 to be withing 5 degrees of the other side. My concern is it a bad idea to leave the tape in place? Will it cause other problems like hot spots on the cylinders/valves?
Is a 30-40 degree spread acceptable for a carbureted engine?
[/URL][/IMG]
[/URL][/IMG]
![Tape2.jpg](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs906.photobucket.com%2Fuser%2Frv4ator%2Fmedia%2FTape2.jpg.html%5D%5BIMG%5Dhttp%3A%2F%2Fi906.photobucket.com%2Falbums%2Fac263%2Frv4ator%2FTape2.jpg&hash=01bb82a47ff70c3d3f9124b3c235e5e7)
![Tape1.jpg](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fs906.photobucket.com%2Fuser%2Frv4ator%2Fmedia%2FTape1.jpg.html%5D%5BIMG%5Dhttp%3A%2F%2Fi906.photobucket.com%2Falbums%2Fac263%2Frv4ator%2FTape1.jpg&hash=688a803593dfee17b77f116f74b7a0e6)
