Pilot com OK with controllers, only com with passenger.
Bought panel mount (EQ SPA 400) and installed per mfg. instructions.
Com great at taxi and low speeds. In the air, I have to throttle back to 21-2300 rpm to com with passenger. Power up to 2650 cruise and static is so great squelch at max. is inop.
Lower rpms both vol. and squelch are OK and operate as should.
Someone said, "filter on rear of alternator may be culprit".
