Matt, Are you sure you have the airport ID correct? I can't find it on Air Nav or AOPA. (OK, never mind, while I was typing this, you fixed your ID. Sorry.)
Thank you for the reply. Unfortunately, both Pep Boys and Tractor Supply no longer carry this part. I also found out Aircraft Spruce does not ship on the weekends. Any other ideas?
I also learned you CAN get a car dolly that works great for moving a RV with a flat tire!
Correct, it is available online, but at that point I should just order the actual tube....which is apparently becoming the only option. Still no luck finding a tube and the old one is beyond repair. Any other RVers in the Fort Lauderdale area with an extra tube for sale? Time is important because I deploy a week from tomorrow
