Paul Thomas
Those pins?
It's a quick connector
I though this tool would do it but I must not know how to use it properly
I feel like I'm having a Bob Collins moment and there is nobody at the airport to help
I'm trying to troubleshoot an electrical problem; we can hear was we believe to be the voltage regulator on the main circuit when the master (alt + battery) is on but the engine is off. We cannot hear that noise once we pull the breaker for the field. Interesting enough, if you pull the breaker for the sense, it also stops the noise and does not resume once you push it back, unlike the field.
Any help is appreciated as if we can't get proper flight testing, the airplane won't make OSH!
