A few specific sealant questions - I am working on the fuselage.
Does the Finish Kit (which has the fuel tank parts) include the Proseal (that is, the Van's Part # MC-236-XX) and if so, how much? Quart? If not, how much is needed to build the tank (and fill the top part of the boarding steps)?
What is the Flamemaster Product code for this product, because I think it might be cheaper elsewhere. I can't make it out on the picture on Vans website.
In particular, I may want to order it along with the Firewall Sealant (the CS-1900 - a different product) from here:
http://www.skygeek.com/flamemaster-cs-1900-sealant-6-oz.html
which is about $20 cheaper than Vans for the firewall sealant. It's not so much the money as I want to get it pretty quick.
It is a bit confusing because the FUEL TANK sealant is used between the lower firewall F-1201C and the F1201-B Firewall Shelf, but later FIREWALL sealant is used on other parts of the firewall.
I am reading other posts about using this stuff but the needed quantity and exact codes are not mentioned. Thanks!
