No audio to headset. Transmit works great. Can Bus works showing Tx and Rx on G3x touch screen. Handheld and two different headsets confirmed working. Wiring & pinouts confirmed min. 4 times.
Mark ( G3x support) agrees either replace it or try " bread boarding" on the bench to eliminate wiring concerns. So I did:
Power and Can Bus are the only connection to aircraft harness; Both work.
A new headset receptacle and wiring installed directly into the radio with 3 pin out confirms and headset proven to work.
Squelch set to 0 in config, tested with SQ and no SQ on screen, no joy so zero to ten options must not be promising ??
You can hear a pop in the headset switching Com on and off.
Ideas to try ?? Otherwise, I order another radio Monday .
