Help -fuel sender data for ACS 2005
rv72004
Could someone please give me the input fiqures for the fuel level settings on the acs 2005 using the float valves. Tail dragger.If possible both for tail down and in flight.
I just dont have a place I can do the fuel level setting .No fuel allowed in drums in hanger, and the fuel bay is just too busy.
If anyone can help it would be appreciated.
Thanks.
You could do what I did, which doesn't require any drums. Buy (or borrow) 3 or 4 five-gallon gas containers (as many as you can get your hands on), and run back and forth between your hangar and the fuel island, putting 2 gal at a time in each container. Yes, it takes a while to do this.
Or...set the zero point and then top 'em off and set the full point. Take linear approximations for now and set them in the midpoints. When you eventually have time to do it right, do it right.
