Toobuilder
I found a fuel leak on the tank outlet (wing root) B nut last night, but as I was turning it with the wrench it became apparent that the tank fitting itself was turning. Sure enough, the jam nut securing the fitting to the tank was a bit loose as well. I tightened the jam nut and then got a little bit more on the B nut ? good news: the leak is fixed. Bad news, I turned the fitting itself a few degrees and I?m thinking my pickup tube is no longer at the bottom of the tank.
Since I don?t have the plans and have never seen inside an -8 tank, does anyone have a picture or drawing (or link to one) handy so that I can see what is going on in there?
Thanks.
Thanks.
