My issue is with the AFS 3500. It's running the second latest software 8.03.28.
I went into the calibration menu to turn on the EGT alarm. When I returned to the main screen the EGT scale was all wonky! I went back into the EGT calibration menu to find the upper scale limit with some crazy number like -1947834455. Thereby when the normal screen is up and a cylinder hits a value of 1400, no bars appear because the scale is all buggered up.
In the calibration menu I hold down the joystick to reset this value, NO LUCK.
I called Advanced. They said to update to the latest software. I downloaded the latest software version 8.08.29 to the SD card. Inserted it. NO LUCK. The EFIS doesn't update anything. Just boots up like normal.
Advanced said that if I install the latest software then I'll be able to reset the value for the top of the scale and then set it back to it's normal 1500.
HELP! I can't get the EFIS to update to the latest software even though it's on the SD card. And I can't get the joystick to reset this upper scale value.
Advanced was closed for the weekend by the time I got home from the hanger, so VAF to the rescue.....I hope. Any ideas or things to try ? I'm at a loss.
Darren
Darren
