tkatc
I am about to slice up this angle as drawn in the plans. Reading this forum has lead me to believe there may be an issue drilling the holes as prescribed. I made a rough template of the holes on the gear tower and have discovered that those holes (factory drilled) will not line up properly if I drill these holes as prescribed. Has anyone solved this problem? Does it matter if the holes are slightly misaligned?
