I will connect a handheld with vor feature to check.
Sorry to tell you but there is no way around it. Both Comm and VOR are in the same RF band (VHF 108-137Mhz) so the only way to know is to follow the coax and see which antenna it is actually connected to....follow the coax to see what it’s attached to.
…..(snip)…If it were only that easy to get a visual on what the coax is connected to.
Perhaps you could post a photo of the antennas mounted in the area of the tail section.
Can you not get to the antennas at all?….I’m having a hard time being able to visualize your situation. If you can at least get to each end of the coax I’d think a simple ohm meter would answer your question.
Antennae on glass birds are commonly buried in the structure so the only visible evidence is the coax connection, wherever the builder decided to put it. Even with that, the detail design of the antenna would be unknown to anyone but the builder.
Can you see what box the cable starts from?
Dave
Coaxial type is not an indication of COM, ELT or VOR use RG58 (which is old school most have gone to RG400).
As said what antenna is back there
If you see nothing then it could have been removed or builder put some hidden antenna in the intersection fairing (typical of Elt antennas) or in Vert or Hroz Stab fairings.
Get antenna analyzer and see what it's FREQ response, impedance if any (open or short).
It really is not Brain Engineering or Rocket Surgery. What other antennas are in the plane and what avionics.
Hi Larry, just to be clear, the warbling will be comm or VOR?
If you are asking about the unit I linked to----you would clip the tone generator to the antenna, and use the probe to test each coax to find the signal. That is, assuming the signal will couple from the antenna to the coax.
I have not tried to trace anything like this, but I can tell you it works great for finding individual runs of CAT 6 in a bundle.
I think it will work in your situation, but not sure.
