miyu1975
Last night I cut the hole for the pitot mast into the wing and also drilled the holes into the mast per instrx. But they came out very slightly crooked.. (I should have drawn a line on the mast so I could see it through the wing skin holes but I didnt) Didn't think to much of it at first but just was wondering if the pitot is not facing perfectly and directly forward will it read correctly. Now obviously if it was way off then I would not be asking as I am sure it would give bad airspeed data. The pitot, once installed, will only (like a 1/2 degree or so) slightly not facing directly forward. any help with this??..sorry no pics right now. What is the margin of err here?
