There was a group of guys that drilled a small hole on the aft side of the vent tube for piece of mind. I'm not sure it's needed, but I remember a thread where several builders / owners did this mod.
The fuel vent inlet is cut so that it puts a small positive pressure on the tank. A hole in the aft side of it will reduce, if not eliminate this pressure.
Just a thought here - but if you're in icing conditions severe enough to ice over a fuel vent - and do it quickly enough that you could pull a vacuum in the tank sufficient to cause a power loss - then you've already got enough ice on the airframe that you're not worried about a power loss anymore. Power is no longer your primary problem.
k. There is no need to have positive pressure on the tank, i.e. Cessna vent right back of the strut. As was stated you want to assure that you don't have a negative pressure on the tank that have adverse effects.
Gary Specketer
Am running the fuel vents but the thought occurred, should they ice up (I will have a heated pitot) there is no alternate fuel vent like on a Cessna fuel cap.
Are my concerns valid?
Thank you for your interest!
Folks, the Andair CK375M and the Aircraft Spruce ACS10630 are check valves only, they won't relieve to atmosphere. Please confirm that it is McMaster-Carr Part No. 4320T13 (Page 460 in catalog) 1/4" tube fittings, that you want to purchase and install. There are different specs that you need to specify when ordering, please confirm also that you want it at 3" water vacuum not as a pressure relief, .5 psi to 10 psi (ref. catalog description)?
Thank you!
on the back of the engine baffel with a 90 degree bulkhead fitting.
Yep they run a -4 hose to the back of the engine baffels right above where the cylinder base bolts to the case. At that location they have a downward facing elbow/bulkhead fitting. I thought that was an excellent place and will probably do that next time.
HMMM, my vents are heated. The vent line travels three or four feet through the heated cabin, then exits the cabin just behind my warm engine with a 1.5" standpipe. I doubt any ice will collect on the vents. I imagine the interior routing was planned on purpose to warm the tube and prevent icing. At least, that's what I am convincing myself of, so don't confuse me with any facts. Someone needs to ask Van's this question.
The vent lines and vents on an RV -9 are heated by the cabin air temperature. I think it is important that you get in contact with Van's on this one before you start to modify the vent system. There is little danger of the stock vents freezing over. Icing only occurs in a relatively small OAT range and the temperature of the collecting surface (vent) must be below freezing. Well, if I can't get my cabin up to at least 60 degrees I doubt it would be a useful cold weather machine. I am sure someone out in RV land has a background in thermodynamics and can speak to this more accurately.
And of course, the plane must be piloted into icing conditions, uh, I am not sure that's a good idea.
Tony Im afraid you are completely wrong on so many fronts.
The Vans fuel vent system is fraut is potential faiure modes due to moisture content freezing that you are not considering.
Suggest reading post 26.
For sure when it is the OAT is 10F.
Has anyone actually experienced this.
You won't get icing when its 10F. And yes I will fly when its below 60F inside the cabin, but I'll complain a lot. Hey I hate the cold, don't ask me why I live in Wisconsin.
There are a hundred combinations that will put ALL RV's in trouble that are flying VFR.
Tell us more please. Which aircraft type? Was the vent system built as per Van's plans, or did it use a coil of tubing in the wing root area? What were the conditions that created the problem? What were the symptoms of the problem? What was the outcome of the flight?Yes.........
If I were still building I might think of adding a small loop in the wing root and placing a check valve at the highest point.
Any comments? Pro or Con.
Kent
One senerio. Im picturing this little ball of water striking my above freezing outside vent tube (warmed by the cowl air mostly) traveling along the vent system with outside pressure pushing and my fuel tank pulling, through my warm toasty cabin, into the wingroot where is cools some, and along the inside of the cold tank where it freezes before exiting into the fuel area. This is my best guess of what happened to me. Whats the check valve going to do? Or are you after a different set of crcumstances?
Why not get a piece of clear tubing, and see what it takes to get a drop of water to climb straight up that 24" rise or whatever it is. I'm not even convinced it can do that. At least not yet.
L.Adamson --- RV6A
The calculation of a vert column is a known ~.85psi on the vertical 2', much much less on a drop, but I dont think that helps any cause in the absense of vertical, which we have here, fluids act funny particularly in smaller cross sections. Where are our fluid dynamicists?
I was the guy who originally posed the question. Again, my fear being that the small area screen inlets would ice up quite readily. One see's the logic as to why a certified airplane vents one cap, runs a crossover to the other vented tank which breathes thru a standpipe.
After all your discussion; I will not place a rubber grommet between the vent line and the fuselage, instead, will leave this open and allow cabin air to flow. Between the heat of the fuel and the heat of the cabin it is reasonable to assume that this area of the vent line will remain warm. I will place an Andair check valve, CK250 (Aircraft Spruce catalog number) with AN-4 fittings on the very top of the vent line run as it loops thru the fuselage. I will use an AN824 tee to splice into the vent line along this run and place the check valve at the 90 degree point of the AN tee, with the arrow pointing on the check valve "in" toward the line. I will do this only on one side (RH), just so I have the peace of mind that there is a back up automatic method of venting a tank other then the venerable externally exposed scupper.
I am no engineer, just another builder (91219). I think this is conservative and am using known aircraft quality components (Andair and AN fittings).
Once again, my sincerest appreciation for allowing me to discuss this with you all.
