The heat 8" muffler fits better on the left pipe than it does on the right (the right one is in the plans). This is because the ball joint on the right hand pipe is lower than the one on the left, leaving the muffler outlet below the firewall flange, if I fit it to the left it's in the right place. I think it will be OK doing it this way but I just wanted to check that I'm not going to have to undo this change further down the line!
