I would like to suggest to check the TCDS (Type Certificate Data Sheet) to see what limitations are on the hub and blade.
The blade used on MY Hartzell prop has a minimum length of 72". IF it were to be reworked to less than the 72", I would be operating in an EXPERIMENTAL area where there is no factory support or data available.
