Mountain Time
Active Member
I have a carbed O-360-A1A with the Hartzell BA prop and McCauley governor, about 450 hrs since new on all of these components.
The last few months, I've noticed a slight hunting or variation in RPM at cruise - say, if set at 2400 RPM with constant throttle position I will see it vary up and down perhaps 10-30 RPM or so. It is just enough to notice it from the sound and feel of the plane, and its visible on the RMI Micromonitor RPM readout. So I don't think it is just an instrumentation issue.
It doesn't happen all the time; sometimes RPM is rock steady, as it has been historically in years past. But then it will go into this slight variation/hunting mode, which may last just a couple minutes, or sometimes longer.
Engine, prop, governor, etc. all seem to work normally in all other respects. Given the symptoms it seems like it must be a governor issue of some kind.
Any suggestions on what this might be, and/or best way to troubleshoot further? Thanks in advance your your suggestions.
