I finally got the rudder pedals hung. In spite of a lot of padding over that sharp edge of the forward part of the seat area my poor ribs took a beating.
The "level" part of the tunnel sides had to be slightly cut (1/8") in order to have the horizontal sections of the pedal assembly go forward enough to align with the nutplates that the assembly is bolted into. I am of the opinion that the assembly sequence should be changed so that the pedal assembly is attached to the overhead panel before they both are riveted to the fuselage.
Putting in the rudder pedal assembly has got to have been to most awkward and difficullt part of building the RV-12 so far, and I have the wings and tail cone connected to the fuselage now. They were easy compared to the pedal hanging.
