hanging engine
scottw
Member
Gents, about to mount the engine 0-320 dyno, presently installing governor and 45 degree oil pressure fitting, my questions at this point are, what is the best orientation of the governor cable bracket to facilitate routing/hookup? and which port/what angle should the pressure fitting be installed in to interfere the least? thanks for the help!
Scott,
If this pressure fitting is located by the upper right engine mount it should be clocked in the 7 or 8 oclock position as you look at the fitting. There is a tool (always is) for mounting the fitting that is nothing more than a tube. The tube screws on to the end of the fitting to get a firm fit. If not installed in the correct position it can interfere with the engine mount, and if not tight enough a weeping leak will exist. Just one of those things you pick up along the way.
