gerrychuck
I have been searching and reading a great deal here on the board on the subject of flying RV-6's at gross weights above those recommended by Van's. I'm familiar with all the wing loading calculations, etc, so I'm comfortable with th concept from a structural point of view. I also understand that an increased gross requires a higher approach speed due to higher stall, etc. and that CG is frequently a major limiting factor.
My question is a simple one (hopefully): If an RV-6A is flown at 1800 lbs (the normal recommended gross for the 7A) will it's flying qualities be substantially different than those of a 7 at the same weight?
Thanks in advance.
Thanks in advance.
