rjcthree
I am considering making a change to my oil cooler now, while it's still easy (baffle fitting and tubing). Right now, I have the Niagra 200002A 7 row, 'EAII' on the firewall. Since it is generally considered 'fact' that the H2 puts more heat into the oil (moves more oil through the heads) it seems like a safe idea to go to 9 or 10 row, and adjust. I see moving to the 9 or 10 row noted on a couple H2 installs, but I've not seen anybody complain about high oil temps with the 7 row cooler . . .
It wil be pushing a fixed Sensenich at 2600rpm max (150hp) on a 9A.
Engine guru's? Thoughts?
Andy, what did you use?
Rick 90432
Rick 90432
