Fastwind67
Member
A while back my attitude indicator was acting "lazy" so I checked into having it overhauled. The cost of overhaul was about the same as a new "imported" gyro from Wag Aero. I asked the repair shop the pros and cons of overhauling my TSO'd indicator vs buying a new imported one. They said the new imported one was basically a disposable unit after 500 hours so I opted to have them overhaul it. I sent it to:
Aircraft Quality Instruments of Wichita Kansas
Less than 150 flight hours later it failed dramatically and begin rotating at about 200 RPM's as if I were doing super fast aileron rolls.
Aircraft Quality Instruments told me it would cost $315 to fix it again. NO THANKS to them. I fly IFR and had just finished a 4.5 hour solid IMC flight right before the failure. I'd of course advise everyone else avoid this company.
So question: For those of you still using vac gyros, where have you bought gyros that are reliable or had gyros overhauled? Also, the panel is set with a 7 degree slant so I need to be able to have the gyro, new or overhauled, set for a 7 degree panel angle.
Referrals to any reputable sources would be appreciated.
