Handclutch
I need to get some stuff from Spruce and thought I would use the opportunity to put some spares on the shelf. Consolidating a number of items into a single order helps reduce shipping costs to Australia which can it get out of hand when buying items individually. Can anybody confirm that the pitch trim servo is the 0.7 inch travel version (aircraft bought flying, so no direct experience)? Based on part numbers I think it should be, but can't be sure. Also, I'm about to tee into the pitot/static system to connect a Garmin G5. The tubing in mine uses white nylon fittings but I am not sure if they were part of the kit or purchased separately. I would like to match them if possible. Spruce lists lists a couple of brands that fit the description. If they were part of the kit can anybody advise which type I should be chasing?
Thanks in anticipation.
Jack
Jack
