Berchmans
I am installing the Garmin GTX 345 with ADS-B in and out. Aircraft is equipped with Dynon FlightDEK 180 using the 1/4 inch pitot/static tubing system with quick disconnect fittings. Does anyone know what fitting I need to flange up with the nylon fitting on the Garmin's static source to adapt to a quick disconnect fitting?
