647jc
I have just started flight tests and I think my XPNDR is not functioning. I'm assuming the indicator next to the numberic #7 on the face of the unit should flash when the unit is interrogated and responds. The manual says nothing about the indicator and I have not had time to check with a tower to see if the unit is responding. I have the airplane down right now for a 5 hr check and before I start crawling around under the panel checking wiring I thought I would first make sure the thing next to the #7 on the face plate is in fact an indicator and it should be flashing when pinged. Everthing else rearding the unit appears to be correct.
I've also included a schematic of my wiring below, anyone see anything that does not appear correct?
![](/proxy.php?image=http%3A%2F%2Fimg519.imageshack.us%2Fimg519%2F3284%2Fxpndrmp3.jpg&hash=28c24049bbbe4ed1e8656818ce40cd57)
