GTN650 Software 6.71 - Change log request
karrelsj
Active Member
Patron
My GTN loader SD cards are sitting in the hangar. Has anyone installed 6.71 yet, and does anyone have the change log on what is in this release?
Asked another way, is this the complete change log:
GTN 6XX/7XX software version 6.71 includes the following:
 Added support to sync databases with GPS 175 and GNC 355.
 ILS/GPS approach annunciate logic has been updated to help address issues with older
autopilots while transitioning to approach mode during turns.
NOTE
When GPS select is configured for prompt, ILS/GPS approach discrete output will not
activate until the message is acknowledged on GTN, allowing the pilot to turn onto final
and then trigger approach mode coupling to the autopilot. This change will only apply to
systems using the ILS/GPS approach discrete output.
 Fixed a problem with Flight data logs being merged into one larger log.
 Added ARINC GDU Format 2 interface for G3X sw v 8.80 which includes fuel flow and fuel
quantity inputs.
