Mr. dynonsupport,
I have just recently been needing to go ahead & get my avionics. I have the D100, D120 & HS34 & planned all along for the 430w. The along came the GTN. I had reservations about the GTN as it was just being introduced so I ordered a 430w. A few days later my supplier called & said that 430 displays were back ordered and would be a couple of months to get one. (made in Japan & they have lots of problems over there now) Nonetheless, I said okay.
Since then, I have stewed over the wisdom of my decision. Then I read in Sport Aviation that Garmin had supplies of GTN's. That set off my queries about the ARINC 429.
At some point down the road, I'll be selling my plane. I figured that the newer equipment would help that cause. I may also upgrade to the Skyview at some point. I decided to bite the bullet and see if I could switch to the GTN650. I was able to, plus about $2K (which included extensive wire harness changes)
All that to say that I'll find out if the GTN & the Dynon "like" each other. I'm betting they will. And, I'm pretty sure someone will find out before me.
Marc:
Thanks for your input. And the elimination of the splitter is worth at least a 100 bucks & some hastle!
