Garmin says the GSU25 should be mounted inline with the center line of the aircraft and on a rigid structure. I don't want to mount it on the back of the G3X because I don't want to have to disconnect the pitot static system to remove the G3X. A professional avionics installer told me he puts the unit in the gear tower, behind the top of the inboard face, which is angled. I am thinking about mounting it against the forward side of one of the gear towers, which I can easily access because I did the gear tower mod. That side is perpendicular to the centerline and the cockpit rails, so it's seems like a perfect place to put the GSU25. Any thoughts or experience with this?
