Duhg
In the process of planning out avionics locations and I'm a little stuck on the GSU (in an RV-8). The manual recommends not mounting with lines pointed up for moisture concerns. Is this an issue when the GSU is already higher than all the external ports and almost all of the line? Lines up seems to be the easiest and most secure orientation.
