GSA28 pitch wiring
Webb
Sponsor
I want to wire the pitch servo and trim servo before riveting on the top aft skin.
I decided to add a GAD27 so I had to re-draw the schematic. Would one of you Garmin gurus please (PLEASE) look at my hand sketch.
The white wires from the trim out pins should go to the servo to drive the trim motor.
The position wires from the servo (orange, blue, green?) go direct to the GEA 24.
So far so good. Thanks.
Shielded cable
Webb
Make sure you use shielded cable from the autopilot servo to the trim motor. As it’s a PWM signal.
Regards Peter
