RedRaider94
Active Member
Hoping someone might have some thoughts on an issue today.
My 1090 radio went bad in my stratux so I replaced it. My stratux has 1090 and 978 - both are working based on my flight today and the stratux GUI interface showing packets being received.
I believe my 330ES is getting 1090 traffic in also.
Both the stratux and 330es are wired to my GRT HX (actually I think the 330es is wired to my 430W which is then sending data to my GRT HX).
Problem I had when testing the stratus today and the new 1090 radio was seeing half of the traffic on the GRT HX as double or overlapping traffic. For example, all of the American Airlines targets had double images (same tail number and altitude and either directly on top of each other or slightly offset where you could tell it was the same plane but showing twice).
I thought Stratux filtered out identical targets such as a 1090 and 978 rebroadcast so I am at a loss as to why I would see doubles.
Is the GRT getting a 1090 target on both the Stratux and 330es and then GRT is showing both? Is it possible Stratux is not filtering and the doubles are a 1090 and 978 message?
Any thoughts would be greatly appreciated!
