Frank N821BF
Active Member
I just finished installing a ADS600 to my SX and it works GREAT. After making several calls to GRT and Navworx to get the settings correct, I thought I would post the settings here. If it only helps one other person, this would be worth it.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
On the 600- Altitude encoder-Shadin Z 9600
GPS source-internal
Transmitter-control panel-EFIS display
On the SX-Set Menu-General Setup
Ser Port #2 out-ALT ENC 2
Ser Port #4 Rate-115200
Ser Port #4 IN ADS-B
Ser Port #4 OUT V-Speed ADS
Traffic Altitude Filter-3800(you can set more or less)
-Set Menu-MAP
Traffic Alert Window-ON
GPS source-internal
-Set Menu-MAP
