GRT sport HS
texdog
Didn’t fly for two weeks and it was hot in the hangar. HS booted up, but scrolled vertically for 10 minutes into the flight, then flickered and finally worked properly. Next day scrolled again, then today it worked from the beginning. I don’t mind sending it to GRT, but if they can’t duplicate the problem, they can’t fix it. Any ideas would be appreciated.
Fred, is it one of the older big case units? Sounds like the one problem I had with a 2009 vintage Sport, something to do with a cable to the display and apparently a known issue. $150 to fix and back in a jiffy.
