GRT OT Sensor alternative
lr172
My GRT OT sensor no longer goes above 165, so time for a new one. I vagely remember that one of their sensors is unique and has no programming options. Does anyone know if I can get an alternate for the GRT OT sensor or do I need to get it from them? Easier to pick up at spruce.
Larry
Larry
Larry,
Not sure if I'm misunderstanding your question, but was just looking into this because the Dynon D180 also allows for the use of a GRT sensor. ACS does carry the GRT FT-LC-01 which I think is one of the legacy sensors you may be referring to. https://www.aircraftspruce.com/catalog/inpages/grt-ft-lc-01.php Or, are you looking for a non-GRT sensor that will work instead?
Hope this helps.
