thanks Dan
I plan on spending a good 12 hours down there on Sat.
I started to put in the EIS engine sensors. Got EGT, CHT, oil temp in place. Need to purchase some AN fittings for the oil and fuel pressure, and make up a little bracket for fuel flow.
should have the fittings and the carb temp sensor by sat. hope to have a/p servos, ahrs, and magnetometer mounted by sat night.
