I am about to order some harness' for various bits and bats and one of them is the GRT. I need to get my wire run lengths right so my question to 7 owners is where in your plane have you put your AHRS? if poss, pics please.
I mounted my AHRS forward of the subpanel on a constructed shelf. This enabled me to to do the following: Keep the wire harness length to a minimum, easy access through the access panels I made in the top forward skin, and easy plumbing for pitot & static hoses.
I also mounted my GRT AHRS forward of the panel, in the front left hand side, on a removeable panel. I have a RV7a slider, and can remove it from under the panel.
