I've thought about carrying one of these (I run the Beringer nose wheel) but keep forgetting to grab one. You could also glue an internal patch on like they do for most auto tires but the advantage with the plug is not having to remove the tire. I've yet to see a flat on an aircraft tire from a puncture, everyone I've seen has been a tube failure usually caused running with low air pressure.
